PhotoRecon
Feb 20, 2012Follower
Does NV+ work with Windows 7 64 bit?
Hi. I have the NV+ (not the NV+ Version 2). Before I purchase hard drives for it, will it work with my Windows 7 OS? Thanks.
mdgm-ntgr
Feb 20, 2012NETGEAR Employee Retired
You have to remember the v1 is an evolutionary improvement over a product (the NV) which was released 6 years ago and as the NV+ (v1) has now been discontinued NetGear no longer produces models running the firmware that the NV+ (v1) runs. It works with Windows 7 now but there's no guarantee that it'll work well with a newer version of Windows once that comes out. It depends what updates are possible for the units and what the increased requirements (if any) are of Windows 8 over Windows 7.
