CNC_Mike
Jul 31, 2021Aspirant
DOS net use access denied to share
Hello, I'm trying to map a share from our new ReadyNAS 3138 with DOS 6.22 running on a CNC machine but have access denied issues. The machine was setup and on the network just fine with our prev...
CNC_Mike
Aug 03, 2021Aspirant
I'm using NetBios over TCP/IP (listed as Microsoft TCPIP in net setup).
We don't have enhanced commands in DOS on most of our DOS 6.22 based CNC machines - unfortunately, no NETSTAT.
Net use paths are F: \\server_name\share. I tried a few different ways to set this up and found DOS prefers server names (does not like IP address) and the user must be setup under C:\NET\setup rather than added into the net use command (although I can set a password with net use).
Upgrading DOS on these machines is not an option.
