BionicManster's avatar
Jan 08, 2016
Drive compatability list is empty for ReadyNAS 104
I am considering purchasing a ReadyNAS 104, but the information on this site says there is no support if you don't pick a drive from the list. When I go to the list, it's blank. I was planning to use ...
  • StephenB's avatar
    Jan 09, 2016
    BionicManster wrote:
    I did find a drop down menu inthe upper right, but changing it doesn't change the titles and commands from German to English.
    I'm not sure if you are having the language problem here or at the HCL site - I have been assuming here. If so, the screen I was directing you to looks like this (in English):
    Is the compatable drive list on a popup?
    The HCL link ( http://kb.netgear.com/app/answers/detail/a_id/20641/~/readynas-hard-disk-compatibility-list ) doesn't create any popups.  There is a pulldown to select the NAS model (and a second pulldown if you select "legacy").
    Then a couple of optional pulldowns to let you filter the list.
ProSupport for Business
