briggs1's avatar
briggs1
Drive failure
My ReadyNAS 1100 (4.1.10) lost power the other day. When it regained power and booted back up it said one of my new 2TB drives was dead. I rebooted it and told it to perform a volume scan on next boot. It came back up and now home page shows it sees all 4 disks but RAIDar still shows the volume status as yellow and 4th disk which had previuosly said was dead has a red x on it.
Volume C: Online, RAID Level 5, 4 disks, 19% of 5554 GB used
On the volume settings page it lists all for disks but the 4th disk has a red & yellow + on it and it doesn't show any disk space allocated like it does for the other disks:
Configuration: RAID Level 5, 4 disks
Status: Not redundant. A disk failure will render this volume dead.
RAID Disks:
Ch 1 : Seagate ST32000641AS [1863 GB] 1860 GB allocated
Ch 2 : Seagate ST32000641AS [1863 GB] 1860 GB allocated
Ch 3 : Seagate ST32000641AS [1863 GB] 1860 GB allocated
Ch 4 : Seagate ST32000641AS [1863 GB]
Does this indicate the disk4 is still bad or does it just mean I will need to re-add it into my raid5? Since I have a raid5 and not x-raid will I have to delete my raid and re-create it?
  • In RAIDar if you click on the help button at the bottom it will bring up a help screen if you look there it shows RAIDar LED Legend
    i think yellow LED is The device has failed or is in a state where it needs attention.
    and green with red/yellow cross is Inactive spare (This disk is a spare disk on standby. If a disk fails, this disk will take over automatically).
  • Okay, so it sounds like I have a spare disk in standby. And the yellow light on my Volume means it is in a state that needs attention. Previously I had all 4 disks in the RAID 5 and all of my lights were green. To fix this I guess I'll have to delete my raid and re-create it with all 4 disks....losing all of my data.
  • StephenB's avatar
    Did you try removing the disk and then reinserting it (with the NAS running)?
ProSupport for Business
