dansenior's avatar
dansenior
Follower
Sep 30, 2015
Drives/Volume inactive #25827208
I have a RN104.  The unit started to disconnect using iSCSI with Windows 10.  Had to repeatly reboot NAS box.  Finally it never came back up and failed boot.  Pulled drives and was able to bring unit back up, but now the unit no longer see Volume.  Says it is inactive.  How can I make active and get to my data?
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    So you have no backup?
    You should follow up with support on this one. They would need a contract in place to look into this.
    • Jedi_Knight's avatar
      Jedi_Knight
      Tutor
      I would suggest work with L3 Tech Support and have Dev take a look.
ProSupport for Business
