Simons101
Jun 16, 2018Aspirant
Dum6a55 corrupted index.html readynas duo v2 sparc and need a copy from someone..
Hi folks.
Did something stupid and corrupted a file.
Index.html from root folder is corrupted and i need a replacement
So if any kind persons out there could upload this file i would ...
- Jun 17, 2018
I've attached what my NV+ v1 has in //frontview/ui/resource/html/index.html
Jun 17, 2018Guru - Experienced User
The labeling on the NAS is a bit confusing, but from the forum's perspective there is no such thing as a duo v2 sparc.
Do you have a v1 system (sparc, 4.1.x firmware), or do you have a v2 (arm processor, 5.3.x firmware)?
Also, when you say "root" do you mean the root of the C data volume? Perhaps give us the actual path you are seeing via ssh.
Simons101
Jun 17, 2018Aspirant
Hi StephenB,
Sorry was half asleep when i posted,
Thanks for the reply.
It is a duo v1 system (sparc, 4.1.x firmware),
The file corrupted is the frontview index.html
Thats it, if you can help that would be great
Thanks
Richard
- StephenBJun 17, 2018Guru - Experienced User
- Simons101Jun 17, 2018Aspirant
Hi StephanB
Thanks for the index.html sadly it didn't fix it must have messed up more than i thought
ssh ed in and used
touch /.os_update
and rebooted which fixed it, think you also posted that fix
So thanks again, i owe you a pint.....
I'm glad you're up and running.
