smh1
Mar 08, 2009Aspirant
Duo: Sharing a scanner using Sane
I've just set up my Duo to provide shared access to an Epson Perfection 1650 scanner using Sane. Previously the scanner was connected to my daughter's PC which was off or in use whenever anyone wanted...
smh1
SANE (http://www.sane-project.org/) - Scanner Access Now Easy - is a Linux-based solution for interfacing with document scanners, which includes provision for sharing a scanner via the network. An additional package - SaneTwain (http://sanetwain.ozuzo.net/) provides the means for PCs running Windows to use the scanner. It does this by bridging between the SANE and TWAIN ( http://www.twain.org/ ) APIs.
Requirements
Requirements
- Backup important data from your ReadyNAS before you start!
- The EnableRootSSH and APT plugins must be installed: http://www.readynas.com/?page_id=94
- PuTTY if you're connecting from a Windows PC: http://www.putty.org/
- You did back up all the important data from your ReadyNAS didn't you? If not, do it now
- Connect to the ReadyNAS using PuTTY or ssh and log in.
(These notes assume you've logging in with a non-root account and use sudo when necessary). - Install the sane-utils package:
sudo apt-get update
sudo apt-get install sane-utils - Plug the scanner into one of the ReadyNAS USB ports and turn it on, then type:
$sudo scanimage -L
Your scanner should be recognised and you'll see something like this (Perfection 1650 and GT-8200 are different names for the same device):
device `epson:libusb:002:004' is a Epson GT-8200 flatbed scanner - Download the sane backend source sane-backends-1.0.19.tar.gz, and extract the libusbscanner script from the tools/hotplug folder.
libusbscanner must be copied into /etc/hotplug/usb - a gotcha here is that /etc/hotplug has no read access for non-root users so this must be done as root. libusbscanner must be made executable:chmod a+x libusbscanner
- The other component needed is a file called libsane.usermap, which is not included in the source package. This file contains details about recognised devices. I found enough references to it on the web to figure out how to create my own in /etc/hotplug/usb. The file I created looks like this:
# Epson Perfection 1650
libusbscanner 0x0003 0x04b8 0x0110 0x0000 0x0000 0x00 0x00 0x00 0x00 0x00 0x00 0x00000000
0x048 and 0x0110 are the vendor and product IDs for the Epson scanner, which you can find for your scanner using the sane-find-scanner command. I’ve no idea what the other fields mean - all the examples I found had them set to 0 as above.
You can create the file in-place using nano or vi, or create it on a ReadyNAS share using another machine and then copy it into place (as root, remember):
cd /etc/hotplug/usb
cp /c/MyShare/libsane.usermap . - A user called saned will have been created when sane-utils was installed. Add this user to the scanners group with:
sudo usermod -G scanner saned - Add this line to /etc/inetd.conf
sane stream tcp nowait saned.saned /usr/sbin/saned saned
The gotcha here is to ensure that the first item in the command (the port - sane in this case) matches the relevant entry in /etc/services:
sane 6566/tcp # SANE network scanner daemon - Edit /etc/sane.d/saned.conf to include a list of the host names or IP addresses that will be able to access the scanner. The default file includes some helpful comments about what's needed. The simplest way to include all the machines on your local network is just to add the subnet mask. For my home network with IP addresses of the form 192.168.0.* I just added:
192.168.0.1/24 - restart inetd
sudo /etc/init.d/inetd restart - For Windows machines, install SaneTwain (http://sanetwain.ozuzo.net/). The documentation is pretty clear: all you really need to do is to tell scanimage the IP address of your ReadyNAS.
I was not able to get the Epson SmartPanel software supplied with the scanner to recognise SaneTwain, but applications like MS Word talk it OK, and scanimage is fine for printing scans or daving them to file. - For Linux clients you must install sane-utils and a SANE Frontend. I found that on my Asus eee running EasyPeasy (Ubuntu-eee) sane-utils and XSane were already installed and worked fine.
Step 1 - Install sane-utils
I found a HowTo guide that gave most of the basic info: http://www.linux.com/feature/57798. It's probably worth reading this and the SANE Documentation before you begin.
Step 2 - Sort out permissions
At this stage, only root will be able to access the scanner. To fix this you must set up hotplug to recognise a usb scanner when it's plugged in and adjust the permissions.
Step 3 - Run the saned daemon
To get network access to the scanner you have to set the saned daemon running
Step 4 - Configure Clients
That's all the server (ReadyNAS) work done - now you just have to set up the client machines that will access the scanner. SANE refers to scanning applications as Frontends and you can find a list of them at http://www.sane-project.org/sane-frontends.html.
