smh1
Mar 08, 2009Aspirant
Duo: Sharing a scanner using Sane
I've just set up my Duo to provide shared access to an Epson Perfection 1650 scanner using Sane. Previously the scanner was connected to my daughter's PC which was off or in use whenever anyone wanted...
Maxx20
May 23, 2011Aspirant
Hey,
I followed all the steps above and I can scan from the command line in the terminal session. The Sane / Twain app just reports the scanner as busy all the time though? If anyone has any hints that would be good.
I'm not keen on buying the add-on as I expect it'll probably do the same as my current setup.
Any hints much appreciated.
