rnas_newbie
May 07, 2012Aspirant
Duo V2 : Remote UPS monitoring:sorted v.5.3.7
edit - **sorted in raidiator 5.3.7** I've had a quick search on the forums and drew a blank...but in the true tradition of the older models; Please can we have the ability for the Duo V2 to moni...
rnas_newbie
Oct 05, 2012Aspirant
thanks Ludovic for the tip :)
I tried the workaround, and all is well for a while - but there seems to be a problem when I reboot, the V2 seems to delete the ups.log file and the ups monitor on frontview is no longer green. Is this a limitation or should i try a reinstall from scratch incase i did anything wrong?
ps - i really do wish the Jedi would confirm a long term/built-in solution is going to be offered soon :(
