Ianlighting
Nov 30, 2011Aspirant
Duo v2 comparison and help please
I've reached the point where i need to get a NAS - partially pushed into it by the death of my pc motherboard, meaning i may aswell completely rethink how the setup of my home system. I've spent a few...
mdgm-ntgr
Nov 30, 2011NETGEAR Employee Retired
Duo v2 (RND2000-200) is available from Nov 13th 2011. It's up to the reseller you use to place an order with their distributor.
It does have USB 3 ports and a new web interface.
There is a comparison chart here: http://www.readynas.com/?cat=49
I think it's pretty clear that not all features intended for the product made it into the first 5.3.1 release. As to what the features are that will be added we'll need to wait and see. Do note this comment: http://www.readynas.com/forum/viewtopic.php?p=330426#p330426
As a beta tester of the Duo v2, I'm very happy with the product and would recommend it.
sphardy wrote:
Neither SBS or Firefly are currently available for the v2 devices though there are ARM ports of both and so it is likely both will eventually appear
