Sandshark
May 16, 2016Sensei
Duo V2 odd network behavior
I'm trying to diagnose a problem with a pair of Duo V2's. What I am finding is that they work fine dirrectly connected to a Netgear router and a Trendnet "green" switch, but not on a D-Link "green" s...
mdgm-ntgr
May 16, 2016NETGEAR Employee Retired
I reckon from your description it's clear that the problem is with the D-Link "green" switch.
Sandshark
May 16, 2016Sensei
mdgm wrote:I reckon from your description it's clear that the problem is with the D-Link "green" switch.
And, yet, it works with every other device connected to it, including other ReadyNASes. So, no, the problem clearly does not lie solely with the switch. It is an interaction between the two devices.
