gmeier03
Apr 09, 2013Aspirant
Duo V2 Partitioned 1TB USB HDD?
Just set up my new Duo V2 and tried copying media files from a WD 1TB USB 3.0 HDD FAT32 to the nas through one of the rear USB ports. It didn't mount so I plugged it into the second rear port then th...
de_niro
Apr 09, 2013Guide
did you see your USB 3.0 device plugged info in Dashboard?Please confirm compatibility of your device on ReadyNAS first,a thing you need to know is that current linux kenel doesn't support USB3.0 very well.can you post kernel log here?
