gmeier03
Apr 09, 2013Aspirant
Duo V2 Partitioned 1TB USB HDD?
Just set up my new Duo V2 and tried copying media files from a WD 1TB USB 3.0 HDD FAT32 to the nas through one of the rear USB ports. It didn't mount so I plugged it into the second rear port then th...
gmeier03
Apr 10, 2013Aspirant
No, it never showed up on the dashboard before the added partitions or after. I'll check the logs but since I've done a factory reset so the original issue won't be logged. I had another issue with ReadyCloud not working either and called Netger support about it. They did the factory reset. I'll post my claim number when I get home.
