gmeier03
Apr 09, 2013Aspirant
Duo V2 Partitioned 1TB USB HDD?
Just set up my new Duo V2 and tried copying media files from a WD 1TB USB 3.0 HDD FAT32 to the nas through one of the rear USB ports. It didn't mount so I plugged it into the second rear port then th...
gmeier03
Apr 10, 2013Aspirant
My case number is: 20925750
Below is the logs of me removing and reinserting the drive in the front USB then trying to force backup from front USB to the Media share.
Apr 10 14:41:18 nas-BE-FC-A8 kernel: usb 1-1: USB disconnect, device number 2
Apr 10 14:41:23 nas-BE-FC-A8 kernel: usb 1-1: new high speed USB device number 3 using ehci_marvell
Apr 10 14:41:23 nas-BE-FC-A8 kernel: scsi3 : usb-storage 1-1:1.0
Apr 10 14:41:24 nas-BE-FC-A8 kernel: scsi 3:0:0:0: Direct-Access WD My Passport 0740 1003 PQ: 0 ANSI: 6
Apr 10 14:41:24 nas-BE-FC-A8 kernel: scsi 3:0:0:1: Enclosure WD SES Device 1003 PQ: 0 ANSI: 6
Apr 10 14:41:24 nas-BE-FC-A8 kernel: sd 3:0:0:0: Attached scsi generic sg1 type 0
Apr 10 14:41:24 nas-BE-FC-A8 kernel: scsi 3:0:0:1: Attached scsi generic sg2 type 13
Apr 10 14:41:31 nas-BE-FC-A8 kernel: sd 3:0:0:0: [sdb] Spinning up disk....ready
Apr 10 14:41:31 nas-BE-FC-A8 kernel: sd 3:0:0:0: [sdb] 1953458176 512-byte logical blocks: (1.00 TB/931 GiB)
Apr 10 14:41:31 nas-BE-FC-A8 kernel: sd 3:0:0:0: [sdb] Write Protect is off
Apr 10 14:41:31 nas-BE-FC-A8 kernel: sd 3:0:0:0: [sdb] Mode Sense: 47 00 10 08
Apr 10 14:41:31 nas-BE-FC-A8 kernel: sd 3:0:0:0: [sdb] Assuming drive cache: write through
Apr 10 14:41:31 nas-BE-FC-A8 kernel: sdb: sdb1 sdb2
Apr 10 14:41:31 nas-BE-FC-A8 kernel: sd 3:0:0:0: [sdb] Attached SCSI disk
