boben
Dec 17, 2014Aspirant
Duo V2 with defect networkcard and no backup
Hi, I have a Duo V2 with 2*2TB discs mirrored. The network card is defect and I have no backup. I think it is running v5.3.11 Is it possible to move the two discs to another duo V2 and retrieve t...
vandermerwe
Dec 17, 2014Master
How do you know the network card is defective?
You would just need a spare disk in the other duo v2 to upgrade the firmware.
There is one other possible option, Netgear has a scheme where, if you buy a new readynas, they will help you to migrate your data. There may be a fee for the migration procedure.
You really should keep backups of your data.
