boben
Dec 17, 2014Aspirant
Duo V2 with defect networkcard and no backup
Hi, I have a Duo V2 with 2*2TB discs mirrored. The network card is defect and I have no backup. I think it is running v5.3.11 Is it possible to move the two discs to another duo V2 and retrieve t...
vandermerwe
Dec 18, 2014Master
Ok, I think you're right, it sounds dead.
I don't think the spare disk factory will achieve anything.
Did you consider my suggestion about a new readynas, I think this would be more sensible than getting another duo v2 which will have no warranty
