Björn_Eberhardt
May 30, 2015Aspirant
Eaton 5115 (and hundreds of other models with USB) supported
TL;DR - it works, upload the Eaton IPP Linux (amd64 or arm) rpm file on the Apps panel, and then RTFM on the Eaton website for instructions or access :4679 with admin/admin. Ignore the UPS warnings fr...
patu_das_botas
Sep 16, 2015Aspirant
Hello Björn_Eberhardt,
I am new to this forum and I have read your post with attention.
Here can I download the arm version of the IPP software from Eaton? I have already filled the basic questionaire about your UPS model and operating system.
Thanks in advance,
Pedro Amorim
- StephenBSep 16, 2015Guru - Experienced User
That software isn't here (this is just ReadyNAS stuff). You need to contact Eaton somehow.
- Björn_EberhardtSep 17, 2015Aspirant
You will find the software Eaton IPP on Eaton's website. You may need to register or enter serial numbers to see download links. I don't remember, sorry :'(
Edit: did you ever read my initial post entirely? (Yes, there is a TL;DR summary. I shouldn't have done that.)
"Downloading it requires you to fill a basic questionaire about your UPS model and operating system."
