DSMIW
Feb 25, 2013Aspirant
Eaton UPS Model 51100700A
I want to use my Eaton 5110 700Va to provide UPS support for my Netgear ReadyNAS NV+ v1 (RND4000). I know they do not officially talk to each other, but please will you tell me if there is a workaround to overcome this.
Many thanks,
Mark
Many thanks,
Mark
- kossbossGuideI honestly dont think so, because thats the way it has been tested. Is getting another UPS not an option?
- DSMIWAspirantGreetings Kostia,
Yes I can get another, compatible UPS, but that seems like a waste. Now having capacity on an existing Eaton 5110 I connected them up assuming it would work. It was only when the ReadyNAS did not show the UPS in Frontview that I checked compatibility. The Eaton support team was very surprised to learn that the 5110 was incompatible with the ReadyNAS. Can you point me at any third party groups that may be able to help?
Thanks,
Mark
