stubbsy1
Mar 13, 2017Guide
EDA500 - larger drive added - incorrect expansion
I am using ReadyNasas OS 6.6.1, have an RN314 and an EDA500 attached. There are 2 volumes. One spans the RN314 and the other the EDA500. The RN314 holds 2 x 6tb and 2 x 4Tb. The EDA500 had 4 x 4Tb d...
- Mar 17, 2017
Do you have an up to date backup?
Perhaps try ReadyNASOS 6.7.0-T206 (Beta 4)
mdgm-ntgr
Mar 13, 2017NETGEAR Employee Retired
Is it still resyncing? Once the resync is complete it should automatically check if it can expand vertically.
