stubbsy1
Mar 13, 2017Guide
EDA500 - larger drive added - incorrect expansion
I am using ReadyNasas OS 6.6.1, have an RN314 and an EDA500 attached. There are 2 volumes. One spans the RN314 and the other the EDA500. The RN314 holds 2 x 6tb and 2 x 4Tb. The EDA500 had 4 x 4Tb d...
- Mar 17, 2017
Do you have an up to date backup?
Perhaps try ReadyNASOS 6.7.0-T206 (Beta 4)
mdgm-ntgr
Mar 13, 2017NETGEAR Employee Retired
Is it still resyncing? Once the resync is complete it should automatically check if it can expand vertically.
stubbsy1
Mar 14, 2017Guide
Thanks mdgm. Yes still going. Oddly while the rn314 has 11:36 to go the eda says 329 hours to go. Time literally will tell.
- stubbsy1Mar 16, 2017Guide
Something really odd is happening here. My EDA500 has taken in excess of 65 hours resyncing. Sometime while I was at work today I am guessing it "finished" since the original issue described below has returned. No green activity light on RN314 and all lights for drives are on (both units), byt yet again the entire unit (essentially the RN314 since it controls things) is unresponsive to a button press and I could not ping it's IP address. I force powered it down and it's started resync again from scratch on both units.
Any suggestions on this? The RN314 says resync will take 17 hours but again the EDA500 has a crazy resync time listed of 320 hours
- mdgm-ntgrMar 17, 2017NETGEAR Employee Retired
