Caesarea
May 03, 2017Guide
EDA500 connecting directly to PC
Before I order the EDA500 Expansion Chassis 5-Bay I want to verify if I can connect the EDA500 directly to my PC with Windows 10. Can anybody help me with this? Is there any compatibity list wit...
- May 13, 2017
The combination EDA500 and StarTech.com 2-port SATA 6 Gbit/s PCI Express eSATA (PEXESAT32) WORKS!!!
But if you connect the second EDA500 to the second port of the PCI, it does NOT work.
Good luck to you all.
Thanks for the responses!
Caesarea
May 04, 2017Guide
I guess the EDA500 eSATA port has a port-multplier functionality. So maybe I can combine the Startech® 2 Port PCI-Express eSATA Controller Adapter Card (PEXESATA2) with the EDA500?
Caesarea
May 05, 2017Guide
I almost sure it has, but can somebody confirm the eSATA port of the EDA500 has port-multplier functionality?
I ordered the EDA500 for a very good price and also ordered the Startech® 2 Port PCI-Express eSATA Controller Adapter Card (PEXESATA2).
I will receive it next week, hopefully...
- EmachineMay 06, 2017Aspirant
I bought also that kind of NAS from Ibood.
Bought and eSATA card to put in the pc, it doens't recognize
Seems this NAS only work when it's conected to an other NetGear Nas like
This release of ReadyNAS OS supports the following ReadyNAS systems: • ReadyNAS 102 • ReadyNAS 104 • ReadyNAS 202 • ReadyNAS 204 • ReadyNAS 212 • ReadyNAS 214 • ReadyNAS 312
- jak0lantashMay 06, 2017Mentor
Emachine wrote:I bought also that kind of NAS from Ibood.
EDA500 is not a NAS, it's an expansion chassis.
And among the ReadyNAS models you listed, only the RN312 is compatible.
http://www.netgear.ie/business/products/storage/readynas/readynas-desktop.aspx#tab-expansion
Maybe you want to look at purchasing a DAS, which sounds closer to want you're looking for.
when I buy a nas RN 102, is than the problem solved ?
http://www.downloads.netgear.com/files/GDC/datasheet/en/RN100.pdf
Thanks in advance
Luc
