hmuessig's avatar
hmuessig
Luminary
Apr 23, 2017
EDA500 and UPS
Quick question: Will the EDA500 expansion chassis shut down gracefully when the 314 it is connected to receives a battery alarm from a UPS? I know the 314 will shut down . . .  but it is unclear from the documentation whether the EDA 500 will also.
Tx!
  • hmuessig's avatar
    hmuessig
    Apr 27, 2017
    EDA500 powers down when the main unit does. As it should.
    Cheers!
  • StephenB's avatar
    AFAIK there is no processor in the EDA500.  So the shutdown on the RN314 should spindown the EDA500 disks, and the chassis should simply turn off when the power runs out.
    Of course the EDA500 also needs to be powered from the same UPS.
    Probably worth testing - simply unplug the main power feed to the UPS and see what happens.
    • hmuessig's avatar
      hmuessig
      Luminary
      The unit is currently resyncing (2 4TB drives, probably over 48 hours to complete).
      So I'll try a forced "power outage" when it is finished syncing and report back.
      Curiously, the status lights on the unit are all dark (the disk activity lights are working). Only the "Netgear" logo is lite. Maybe when it is finished "resyncing"?
      Tx StephanB!
    • jak0lantash's avatar
      jak0lantash
      Mentor
      I concur, you should test this. Regardless of what the documentation of what you find say, this is probably a not-so-common situation, so testing is definitely worth it.
      Please post back for future reference ;)
      • hmuessig's avatar
        hmuessig
        Luminary
        Cheers!
ProSupport for Business
