ReadyNASser's avatar
Mar 29, 2017
CyberPower CP850PFCLCD PFC Sinewave UPS compatible with RN526X + EDA500?
Is the CyberPower CP850PFCLCD PFC Sinewave UPS compatible with RN526X + EDA500?
Thanks!
  • I can't speak to that specific model, but I will say that I've used a CyberPower model under that one that Costco sells and currently use the next series up from that one and both have worked well with ReadyNAS.
    • ReadyNASser's avatar
      ReadyNASser
      Tutor
      Thanks for the input! I've since found some mentions of this specific UPS model in a few other threads on here from people using it with other ReadyNAS's, so I don't see why it shouldn't work with my RN526X. I have another CP850PFCLCD doing a great job protecting my iMac with its active PFC power supply (which doesn't like simulated/stepped sine wave UPS). I will only be connecting the RN526X, EDA500, and my router to it, so it should provide enough time to shut everything down gracefully in the event of an extended outage.
ProSupport for Business
