Caesarea
May 03, 2017Guide
EDA500 connecting directly to PC
Before I order the EDA500 Expansion Chassis 5-Bay I want to verify if I can connect the EDA500 directly to my PC with Windows 10. Can anybody help me with this? Is there any compatibity list wit...
- May 13, 2017
The combination EDA500 and StarTech.com 2-port SATA 6 Gbit/s PCI Express eSATA (PEXESAT32) WORKS!!!
But if you connect the second EDA500 to the second port of the PCI, it does NOT work.
Good luck to you all.
Thanks for the responses!
Sandshark
May 06, 2017Sensei
If by "access your drives" you mean read data from them that's already on them, then no. The NAS will need to re-format them to a Linux format before you can use them, which will wipe out all data. If you mean "make use of the drives", then yes.
Emachine
May 06, 2017Aspirant
On my 4 drives of 4TB are musicvideo's.
So this means when I want to use the 4TB drives, than I need to format them in Linux, and all my musicvideo's are gone.
Than better I send the EDA500 back to the shop ;)
Many thanks for your help
Greetings,
Luc
- SandsharkMay 06, 2017Sensei
Does your PC eSATA controller support port multiplication? If it doesn't say it does, it probably doesn't. Most motherboard eSATA connections don't. That could be why it's not working for you on the PC. Or, it just may not be possible. The OP posted that he is getting a controller that does support it, so you may want to wait and see if he has better luck. But even if it does work, you might not be able to use your drives with the data on them. I can't see the part number on the big IC well enough in the pictures, but it looks to be something more than just a SATA multiplier, quite likely programmable.
You definately don't want to use those drives in a NAS (internally or in an expansion chassis), as the contents will be wiped. I think you should be looking for a USB3 or SATA drive dock. Note that a DAS that uses RAID (such as a Drobo 5c or 5d) is also not what you want, as they also need to reformat the drives to create the RAID. Make sure it states it suports drives of at least 4TB. I'd expect anything with USB3 to do so, but never assume. I'm not aware of any Netgear product that's designed for what you want.
- jak0lantashMay 06, 2017Mentor
Directly purchasing a DAS seems a lot less painful than trying to repurpose an EDA500. Two-minutes-amazon-search examples:
https://www.amazon.com/Mediasonic-ProBox-HF2-SU3S2-SATA-Enclosure/dp/B003X26VV4/
https://www.amazon.com/ORICO-9558RU3-Enclosure-Connection-Aluminum/dp/B00WHMT604/
- StephenBMay 07, 2017Guru - Experienced User
At ~$125 the EDA500 might be worth buying just to get the 6 drive trays.
Even if it does work in a PC, you would lose USB (which the Orico has). But the EDA is $50 cheaper than the ORICO and has the same number of live bays. So if someone here found it works in a PC, then probably are folks here who might go for it.
