felixmartin1
Nov 11, 2013Aspirant
EMPTY in Frontview...
Most of the fields appear EMPTY on Frontview. My files are still accessible, but I can manage the ReadyNAS PRO It is spotty, I can access sometimes, most of the time not. I have had messages of i...
Sandshark
Nov 17, 2013Sensei
That can be caused by an Apache configuration problem. An OS re-load will often fix it. It shouldn't cause you to lose anything, but a backup is always a good idea. Since you should also be backing up before replacing the drive, now it the perfect time to give it a shot. And if that doesn't work, then the full factory default is the next thing to try. That, of course, does erase the drives.
