acraigl
Jan 21, 2018Tutor
Encountered issue with 6.9.2
I've only had the RN214 for a few days, but everything has been going pretty well overall and I'm impressed with what I'm seeing over my VERY old windows home server. When I got it up and runnin...
- Jan 22, 2018
You can hot-swap with a replacement disk. The NAS will then format the replacement disk and add it to the array.
If the disk is already formatted you'd need to go into the web admin UI and format the disk there.
mdgm-ntgr
Jan 21, 2018NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
- Mar 10, 2018Retired_Member
