mr_cello
Mar 27, 2015Aspirant
Encryption, backup and the RN314
I am considering buying an RN314 but am curious about the encryption feature. As I understand it the encryption is per volume. Is it possible to create more than one volume? If so are their any implic...
Mar 28, 2015Guru - Experienced User
Yes
mr.cello wrote: Thanks StephenB. Is the bit locker SW you refer to the built in stuff in windows?
Yes
mr.cello wrote: Presumably from a NAS backup perspective the VHD is simply another file?
