Ianspeed
Feb 11, 2022Aspirant
ERR_SSL_VERSION_OR_CIPHER_MISMATCH after Chrome update
ERR_SSL_VERSION_OR_CIPHER_MISMATCH Can no longer acess any of my 5 drives (5 x RND2110v2 units) admin pages through any browser, I managed to get on briefly before my one machine upgraded Chrome to ...
Feb 11, 2022Guru - Experienced User
Can no longer acess any of my 5 drives (5 x RND2110v2 units) admin pages through any browser, I managed to get on briefly before my one machine upgraded Chrome to the latest version, I quickly checked my Chrome version and saw it was at 21% on the chrome update then when I wen't back 10 seconds later in it was a no go, no access from that machine either now.
I've confirmed this fails with Chrome 98 (though it does work with Chrome 97). Also, it fails with Edge. I'm not seeing any workaround with those two browsers.
If IE is still installed on your PC, then that will still work (at least for now).
You can also install FireFox 94.0.2 (or older) - that also works. But you do need make sure you turn off automatic updates. Then only use FF to reach the NAS (or other websites on your home network), as it will not have up to date security patches.
Ianspeed
Thanks Stephen,
I guess there is absolutely no hope of a patch for these units? I have downloaded Chromium as an interim due to the fact that I use up to date browers Chrome and FF at the same time for checking customers work, so the older version of FF would become an issue sooner or later.
Thanks
Ian
- StephenBFeb 11, 2022Guru - Experienced User
Ianspeed wrote:I guess there is absolutely no hope of a patch for these units?
WhoCares_ might be able to create a patch. He runs rnxtras.com. If he doesn't chime in here, try emailing info@rnxtras.com.
There are two potential paths - one is to update the ssl library on the legacyNAS (and make sure apache is set up to use it properly). That could be quite difficult.
The other is to reconfigure apache so that doesn't advertise/redirect to https. Then http://nas/admin should work, and https would be completely disabled. That would likely be easier.
FWIW, someone did manage to implement the second option on their 5.3.x system: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/ReadyNAS-NV-V2-TLS-Support-may-not-be-able-to-access-soon/td-p/1873534 His edits look like they'd also apply to 4.1.x firmware (other than the SSLProxyEngine bit in httpd.conf). But I've never tried them.
I can't do anything with 4.2.x firmware, because I no longer have any ReadyNAS running that firmware.
- shmulikwFeb 14, 2022Aspirant
im shocked!!
trying to login for few days
didnt imagine it is an update problem
tried firefox
tried safari on a macall it shows is the shares screen
but i cant go to the admin.
it is a serious problem
i expect Netgear to get it fixed ASAP
dont know how
beacause we cannot admin it
- StephenBFeb 14, 2022Guru - Experienced User
shmulikw wrote:i expect Netgear to get it fixed ASAP
They might. But they announced years ago that they would no longer provide updates or fixes for legacy ReadyNAS.
shmulikw wrote:
tried firefox
You need to install an older browser version. 94.0.2 worked for me on Windows. You do need to immediately disable automatic updates, otherwise it will update to the version that doesn't work. https://support.mozilla.org/en-US/kb/install-older-version-firefox
You can find a mac dmg for this version here: https://ftp.mozilla.org/pub/firefox/releases/94.0.2/
