Ianspeed
Feb 11, 2022Aspirant
ERR_SSL_VERSION_OR_CIPHER_MISMATCH after Chrome update
ERR_SSL_VERSION_OR_CIPHER_MISMATCH Can no longer acess any of my 5 drives (5 x RND2110v2 units) admin pages through any browser, I managed to get on briefly before my one machine upgraded Chrome to ...
Feb 11, 2022Guru - Experienced User
Ianspeed wrote:I guess there is absolutely no hope of a patch for these units?
WhoCares_ might be able to create a patch. He runs rnxtras.com. If he doesn't chime in here, try emailing info@rnxtras.com.
There are two potential paths - one is to update the ssl library on the legacyNAS (and make sure apache is set up to use it properly). That could be quite difficult.
The other is to reconfigure apache so that doesn't advertise/redirect to https. Then http://nas/admin should work, and https would be completely disabled. That would likely be easier.
FWIW, someone did manage to implement the second option on their 5.3.x system: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/ReadyNAS-NV-V2-TLS-Support-may-not-be-able-to-access-soon/td-p/1873534 His edits look like they'd also apply to 4.1.x firmware (other than the SSLProxyEngine bit in httpd.conf). But I've never tried them.
I can't do anything with 4.2.x firmware, because I no longer have any ReadyNAS running that firmware.
shmulikw
Feb 14, 2022Aspirant
im shocked!!
trying to login for few days
didnt imagine it is an update problem
tried firefox
tried safari on a mac
all it shows is the shares screen
but i cant go to the admin.
it is a serious problem
i expect Netgear to get it fixed ASAP
dont know how
beacause we cannot admin it
- StephenBFeb 14, 2022Guru - Experienced User
shmulikw wrote:i expect Netgear to get it fixed ASAP
They might. But they announced years ago that they would no longer provide updates or fixes for legacy ReadyNAS.
shmulikw wrote:
tried firefox
You need to install an older browser version. 94.0.2 worked for me on Windows. You do need to immediately disable automatic updates, otherwise it will update to the version that doesn't work. https://support.mozilla.org/en-US/kb/install-older-version-firefox
You can find a mac dmg for this version here: https://ftp.mozilla.org/pub/firefox/releases/94.0.2/
- shmulikwFeb 14, 2022Aspirant
thank you very much
the old version did the trick
thanks for the save :-)
