Gaisgais13
Feb 06, 2022Initiate
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
How can I solve this error??
lksndrs
Mar 07, 2022Aspirant
Actually my device is a ReadyNAS DUO RND2150 with 2 hard disk 500GB.
I've also got the problem ERR_SSL_VERSION_OR_CIPHER_MISMATCH when trying to access the device front panel RAIDiator 4.1.14. I managed to access it with an old browser. Can you explain how to fix the problem? If I need to update firmware where do I find it and how do install it? Thank you for your help.
- SandsharkMar 07, 2022Sensei
Go to the link provided above.
- StephenBMar 08, 2022Guru - Experienced User
