sorenbs
Mar 24, 2022Aspirant
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
I am confused about the exact model: The sign on the bottom says "ReadyNAS Duo RND2150v2", but it is running Raidar 4.1.16 and has 2x1TB disks. When I try to access the Setup option I am suddenly ge...
sorenbs
Mar 26, 2022Aspirant
Thank you for the information- both about my version confusion and for clarification of the TLS mismatch Error. Just after I postet my question I discovered that I can accessFrontview from the browser in my Ipad (running IpadOS 15.3.1).
Based on your response I spent som time (no, a lot of time) investigating the posibilities and finally I chose to access Frontview through Firefox on my PC.
I still have problems with my backup - even though my backup settings worked fine before i had the TLS mismatch error.
sorenbs
Apr 02, 2022Aspirant
@StephenB
Now I have been working on the referred workaround. I get stuck in step 3:
"Go into settings->EOL Conversion of Notepad++, and choose "unix". "
It seems that my version of Notepad++ doesn't offer this option (see picture)
I have been trough all the shown options. It is probably due to lack of expertice, so maybe you can help me on thisone as well.
