mnr
Apr 14, 2017Aspirant
"ERR: Used Disks" After Reboot
A few days ago, I started a defragmentation of my X-raid array of four disks due to declining access speed. While I had never done this before with the ReadyNAS, I naively expected a similar experie...
- Apr 14, 2017
Looks like your removal and readding of disk 4 was the problem.
Rebooting.
mdgm-ntgr
Apr 14, 2017NETGEAR Employee Retired
Well if you have that much data on just the one device it can't be that important. If you value your data you shouldn't store it on just the one device.
My guess would be a full 4GB root volume that's failing to mount.
I've sent you a PM.
