Bruce_In_Philly
Oct 13, 2023Aspirant
Error Communicating with UPS via NAS - Two NASs, one UPS
Summary: One NAS is connected to the UPS, the other NAS signals the other NAS for UPS status and sends error messages every other day or so...this appears to be a NAS-to-NAS issue, not a UPS issue. ...
Oct 14, 2023Guru - Experienced User
Bruce_In_Philly wrote:
UPS is plugged directly into USB port on Storage-0 and shows a correct connection to the UPS
Storage-1 is configured in System/Power/UPS to connect to "UPS 192.168.50.59" which is the other NAS
Both NASs are plugged via Ethernet into the same Ethernet switch.
I am getting emails from Storage-1 denoting "Error communicating with UPS "UPS"()" and then another within seconds denoting "Communication with UPS 'UPS' () is OK."
Frequency email pair is every 1 to 2 to 3 days. Logs are getting filled up with these messages.
I get no emails from Storage-0 that is connected directly to the UPS.
Appears that maybe a timeout should be increased a bit?
Ideas?
Sandshark got these messages a while back on one of his setups - not sure if he ever sorted out what was happening or not.
I've also seen these errors, but if I remember correctly it was with a USB-connected CyberPower UPS, so maybe not the same.
There are a couple of parameters that you could set in upsmon.conf (in \etc\nut)
Not sure when or if the readynas firmware overwrites this file. Generally I keep both the original and my mod handy, so I can re-apply the fix easily (in this case, I'd create \etc\nut\upsmon.conf.orig and \etc\nut\upsmon.conf.mod, and also keep a copy of both somewhere else, in case I needed a factory default later on).
If it rewrites it every time the NAS is booted, you could try setting file permissions to prevent that.
Looking through the doc, I don't think changing the polling parameters will help. Changing
NOTIFYFLAG COMMOK EXEC
NOTIFYFLAG COMMBAD EXEC
to
NOTIFYFLAG COMMOK IGNORE
NOTIFYFLAG COMMBAD IGNORE
should suppress the messages (not something I've ever tried, but what I'd do first).
It looks like it is possible to do something more elaborate with the NUT CMDSCRIPT capability if you were so inclined. Chapter 7 in the NUT manual has more info on this.
One thought on debugging this stuff safely -
You do want to make sure that any mods don't interfere with the shutdown when power is lost.
Moving the NAS power so it isn't connected to the UPS power (but leaving the monitoring paths ok) might be useful. Connect a different load to the UPS (something that will drain the battery reasonably quickly without damaging anything). Then you can make sure that the shutdown still happens cleanly, without risking an unclean shutdown when the battery drains.
Bruce_In_Philly
Oct 14, 2023Aspirant
Thanx... I will look into this... maybe a bit over my pay grade, but I will dig in... First thing to do is run a test to ensure the NAS will shut down per the UPS run down... I did this a while ago and all was good, but will try again.
Peace
Bruce in Philly
