efalsken
Jul 02, 2012Aspirant
eSATA RAID Enclosure/port multiplier
I've got a ReadyNAS Pro (6-drive version) with lots of disks in it that are approaching full. Since I've already got 2TB disks in each slot, I'm starting to look at further possible expansions. One of...
mdgm-ntgr
Jul 02, 2012NETGEAR Employee Retired
The only supported way to add storage to your Pro if all 6 drives bay are full and you don't wish to replace the disks with higher capacity ones would be to add USB drives. eSATA is not supported.
