jonl0711
Feb 11, 2017Aspirant
Expanding the EDA500
I had a EDA500 attached to a RNAS314. The 314 is set for Raid5 with 4 x 3TB drives. The Expansion unit has 2 x3TB drives in a separate volume RAID1. I would like to either expand this volume by ad...
aalexandrebeta
Feb 12, 2017Master
It depends of what you want.
if you want another RAID1 3Tb why not?
If you want 4x3Tb RAID 5 why not?
1st solution is quick and and easy but you loose 1HDD
2nd pretty long and you have to add parity and wait for building and doing things properly!
TAKE YOUR TIME IS THE KEY!!
