jonl0711
Feb 11, 2017Aspirant
Expanding the EDA500
I had a EDA500 attached to a RNAS314. The 314 is set for Raid5 with 4 x 3TB drives. The Expansion unit has 2 x3TB drives in a separate volume RAID1. I would like to either expand this volume by ad...
jonl0711
Feb 16, 2017Aspirant
I've noticed that I made an error the RNAS314 has 4 x 5TB and the EDA500 has 2 x 5TB drives.
Excuse the 2nd question.
With 3 bays left to put drives in does it matter if the drives are 5 TB or can I use smaller drives as long as they are the same size?
aalexandrebeta
Feb 16, 2017Master
You can put whatever HDD in your available slots, it all depends on what is goal and what you want to do with it!
So what are your issues?
How can I help you?
