freddyfruitbat
Oct 07, 2013Guide
External USB backup drive spinning continuously
I've bought a Seagate Expansion 1Tb USB 3.0 2.5" external drive specifically for use as a daily backup device for my ReadyNAS Duo v2; it is therefore plugged in continuously because the ReadyNAS does ...
Oct 09, 2013Guru - Experienced User
Personally I believe that disk spindown does no harm if you don't do it too much -- with no real evidence ... It is surprising that there is so little information available on this topic. It's a pretty simple question, and you'd think that one of the academic papers or the drive manufacturers would have answered it.
fastfwd wrote: ...because I believe -- with no real evidence -- ...
