BMac2021
Dec 26, 2023Tutor
External USB Backup-How to access it
Good morning team...Hoping someone can help me like in the past.... I have (had) a ReadyNASRNDP6000 and today it failed..Yup christmas eve...Went downstairs to find that there was an electrical fire ...
- Dec 28, 2023
Replacing just the main board is risky where there is such significant damage, as there could be secondary damage of the small daughterboard, SATA backplane, and/or power supply. You should also check the drives using the manufacturer's tools. When you do look for a replacement, be aware that the RNDP6000-100 and RNDP6000-200 have very different processors but are otherwise electrically identical. The earliest -100 also shipped with the older round-button caddies, but you can use your old ones, anyway. The CPU in the -100 can also be upgraded.
You are not limited to another similar model, either. Since you already upgraded to OS6, any ReadyNAS with at least 6 bays will accept your volume (assuming it's undamaged) and your old-style caddies will fit even the newest models (since many are sold without caddies).
BMac2021
Dec 26, 2023Tutor
it was updated to 6 firmware.
I might have found a solution to read the drive using R-Linux
Still reading the drive now...fingers crossed
Dec 26, 2023Guru - Experienced User
Likely you formatted the drive as ext - which is not a format that Windows can read. R-linux is one tool that can.
If you get another NAS, then I suggest using NTFS formatting for your backups.
- BMac2021Dec 27, 2023Tutor
So R-Linux worked! It restored almost all my files on the external USB drive.
Now, I am wondering if anyone has a main board that they want to sell?
- SandsharkDec 28, 2023Sensei
