PCullen
Jul 07, 2011Follower
Extra 2Gb drive for Duo - Missing screws...
Hi all, I bought a 2TB readynas duo and at the time got a free 2TB drive. Problem is I hadnt got round to putting the extra drive in for RAID until recently. I do not seem to have the screws to atta...
PapaBear1
Aug 24, 2011Apprentice
They may not be the same then. When this issue has arisen in the past, this was recommended by another member and I kept the link. At one time Yoh-dah had the actual specification drawing of the Infrant/Netgear screw on the forum, but the image hosting site has closed down. I compared the listing from Discount Technology with the original drawing and the only difference I could tell is that the Infrant/Netgear screws are 4MM long and the ones from Discount Technology are 1/4" long. A tad bit longer (6.4 mm) but most drive holes are more than deep enough. It was the flat head that is important.
Open an online case with tech support, start a new discussion in the forum and be sure to add the case number at the end of the subject line. If you don't get a good response from tech support, post the response and hopefully a Jedi will see the discussion that pound on the heads of tech support. I am sorry to have wasted your time and money. I am assuming you "borrowed" a couple of screws from the panel attachment points to get your drive in service.
