thelinuxfr
Oct 21, 2011Guide
Fail2ban in FrontView
Hi, fail2ban installed by default and manageable via the FrontView services with SSH, FTP, HTTP ... Thx
crumb
Jan 05, 2013Aspirant
hello
that's right fail2ban is really appreciate. I have few peoples all over the worlds who tried to connect to my Readynas ultra.
i can see then when i do a :
cat /var/log/auth.log | grep Failed
so, i tried to make a :
sudo apt-get install fail2ban
but i always have a problem when it tried to configure itself after the installation ... agreed to the log, there is a problem with python (python2.4 is required)
i have python 2.7 i installed in frontview from : http://readynasxtras.com/readynas-x86-add-ons/python-26-x86
so i tried to :
apt-get remove --purge fail2ban
apt-get autoremove
but same problem again and again.
Finnaly it worked when i install fail2ban with the sources :
- Downladed http://sourceforge.net/projects/fail2ban/?source=dlp
- untar and cp in the new directory
- python setup.py install
and then, it worked !!!
so after that i had to configure fail2ban :
edit /etc/fail2ban/jail.local (which is a copy of the original jail.conf to preserve the original conf)
i turned
then made a
fail2ban-client reload
fail2ban-client status
which respond a :
then i tried to connect to my readynas with a 3G smartphone, and failed 6 times to the password
>> my 3G IP was banned, and i automaticly received a mail which tell me which IP was BAN.
/var/log/fail2ban.log give me that :
so i tried to :
apt-get autoremove
i turned
[ssh-iptables]
enabled = true
port = ssh,22
logpath = /var/log/auth.log
[proftpd-iptables]
enabled = true
port = ftp,sftp,"my specific port"
logpath = /var/log/proftpd.log
then made a
which respond a :
Status
|- Number of jail: 2
`- Jail list: proftpd-iptables, ssh-iptables
2013-01-05 18:04:46,453 fail2ban.actions: WARNING [ssh-iptables] Ban 37.8.177.xx
2013-01-05 18:14:46,828 fail2ban.actions: WARNING [ssh-iptables] Unban 37.8.177.xx
