RCT-AU
Jul 04, 2021Follower
Failed drive, can it run on 3?
One Drive has predictive failure, will the raid5 cope for a couple of weeks while I wait for Seagate warranty process, am I hoping for too much? I understand the load on the remaining drives will incr...
Jul 04, 2021Guru - Experienced User
The risk is that a second drive will fail while you are waiting. If that doesn't happen you should be ok.
