meisner
Apr 26, 2017Guide
Upgrade to WD30EFRX drives is failing
ReadyNAS Ultra 2
RAIDiator 4.2.30 (Latest)
My old 3TB Seagates are failing so I am trying to replace them with WD WD30EFRX drives. The drives are supported according to the HCL (https://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List?cid=wmt_netgear_organic) but they sure seem as though as they are not supported. I can hotswap drive 2 with a WD and let it rebuild the array against the old Seagate, but when I put a WD in slot 1, it won't start up. I just get the nas-XX-XX-XX boot prompt on port 23.
This is getting a bit urgent as I am getting more and more SMART errors on the old drives. Can someone please help me?!?!?
Solutions to my original problem are spread out across multiple posts:
- Do a factory reset:
- I think using dd or hdparam is very useful:
- But I also feel the discovery I made was critical:
Thanks to all that helped out. Restore is complete and I have been running a couple of days now with the new drives. I even powered down to move the ReadyNAS into its permanent location.
The WD30EFRX do work (I have 6 in my Pro-6).
Perhaps one of them is DOA? Did you try testing the one in slot 1 with WDC's Lifeguard program?
If the one in slot-2 has synced, you can try powering down, removing the seagate, and then see if it boots.
- meisnerGuide
I have not tried the Lifeguard program. Should I use that prior to expecting the drives to work in the ReadyNAS?
I did exactly that last night and it just went to the nas-XX-XX-XX boot menu (seen via telnet).
If I run the Seagate in slot 1 and either WDs in slot 2, it syncs. If I remove the Seagate, I get the boot menu only. I also tried just one of the WDs in slot 1 and that didn't work either.
Sometimes drives are DOA, so I do run it if I have the time.
I suggest a full backup of the data (esp. since the Seagates are failing).
Then shut down the NAS, put in both the WDs, and do a factory reset from the boot menu. That will do a clean factory install. If that works ok, then reconfigure the NAS and restore the data from the backup.
