jcastillo's avatar
jcastillo
Firmware Upgrade failed
 Hello, we have a Netgear FS726TP that I am upgrading the firmware, What I dod was unplug everything, but my laptop, Then I placed my adapter to 192.168.0.X
network, and opened up SmartControl Center. it recognized my switch, but with an older firmware, 2.01_05. I tried upgrading to the latest firmware 2.01_14. When I did the upgrade, the firmware shows version "e", not 2.01_14, like it should. Can you help me or point me in the right direction?
  • JohnRo's avatar
    JohnRo
    Sep 01, 2015
    Hello jcastillo,
    Welcome to the community!
    Regarding your issue with the firmware update, try upgrading in a ladderized manner install 2.0.1_09 before jumping to 2.0.1_14. After performing the firmware upgrade, perform a factory reset by pushing the factory defaults button for 10 seconds.
    Hope this helps, I'll look forward to your response.
    Thanks,
  • Also, I forgot to mention that no matter what settings I apply, they will not stay after a reboot. Everything goes back to default.
    • JohnRo's avatar
      JohnRo
      NETGEAR Employee Retired
      Hello jcastillo,
      Thanks,
ProSupport for Business
