Rob_Robertson
Apr 24, 2019Aspirant
Failed Upgrade from 6.9.5 to 6.10.0 RN516
I upgrade FW from 6.9.5 to 6.10.0 via the OS and auto update.
On restart the system reaches 99% and hangs
When I toggle the power switch the lcd rotates between booting and MySQL.service
antileech
Apr 26, 2019Aspirant
Same here, my RN314 is stuck at 99%
JohnCM_S
Apr 30, 2019NETGEAR Employee Retired
Hi antileech,
Welcome to the Community!
Have you tried doing the OS reinstall? If yes, what was the result?
Here is the link if you need the steps on how to access the boot menu and do the OS reinstall.
- antileechApr 30, 2019AspirantOS reinstall worked for me. Had to redo all my sharing and user permissions though. Haven't run into any other problems since.
Thnx- JohnCM_SApr 30, 2019NETGEAR Employee Retired
Hi antileech,
Thanks for the feedback. It is good to hear that OS reinstall fixed the issue on your NAS. :)
