hawke84
Mar 03, 2015Tutor
Fan Control
Hi, I dont know if this has been requested, I cant find it anywhere. I was wondering if its possible to create a fan speed control gui app. I understand there is already an init.d script to change f...
RX
Mar 03, 2015Luminary
It would be best if you will open a case with Netgear Support and raise your concern as feature request.
https://my.netgear.com/registration/login.aspx
