AndreasKa
Jan 05, 2015Tutor
Fan speed control
Apologies if this has been requested before. Living in a warmer climate (Singapore) ad having just setup my RN314 with a single 500GB drive for testing. I can already see CPU temps hitting 55c+ and...
AndreasKa
Jan 13, 2015Tutor
mdgm wrote: The fans will spin up when needed. What version of ReadyNAS OS are you running?
mdgm wrote: 40c is well below the safe maximum level. It is fine for temps to go higher than that.
OK so the unit is now fully populated, with drives under zero load i.e. the unit is just running and I haven't configured any volumes.
At no point have I seen the fan increase over 800rpm and the temps continued to rise.
Drive 4 is a WD Se unit and I have to say that 48c is approaching concerning levels when the specs of the drive state 55c max operating temp.
Could the team please look into a way of providing an official way to have at least some control over the lowest fan speed?
Fan - 750RPM
CPU - 53
system - 39
Disk 1 - 43
Disk 2 - 41
Disk 3 - 45
Disk 4 - 48
