Equinox1
Jun 03, 2015Guide
Fans in Pro 6
I bought a pimped-up Pro 6, and the fans are running in reverse: the side air is pushing hot air out of the CPU, and the rear fan is sucking cold air instead of extracting the hot air. I'm not sur...
- Jun 11, 2015New episodes... I think the guy that installed all these after market components reversed the big fan in the rear. I couldnt touch the other ones, so I just reversed that one. The CPU (indeed, the kozuti) and the other small fan in the back arent possible to dismantle without taking everything apart.
When I put it back together, I got a normal airflow, and -15 C on the CPU:
- now the air comes in from the side and the front, and gets through the back
- the cpu is at 45 c in normal usage
- the system temp is at 60 C in normal usage
- fan RPMs rarely exceed 960RPM
I believe this is much more inline with a normal behavior than before. :-)
Thanks for the tips, itsjasper!
itsjasper
Jun 08, 2015Luminary
That CPU cooler looks like a Scythe Kozuti SCKZT-1000 to me: http://www.frostytech.com/articleview.cfm?articleID=2614
Seems likely that both the rear fan and the CPU fan airflow directions were reversed, as the fan on the CPU cooler should draw in air according to the instructions.
