Equinox1
Jun 03, 2015Guide
Fans in Pro 6
I bought a pimped-up Pro 6, and the fans are running in reverse: the side air is pushing hot air out of the CPU, and the rear fan is sucking cold air instead of extracting the hot air. I'm not sur...
- Jun 11, 2015New episodes... I think the guy that installed all these after market components reversed the big fan in the rear. I couldnt touch the other ones, so I just reversed that one. The CPU (indeed, the kozuti) and the other small fan in the back arent possible to dismantle without taking everything apart.
When I put it back together, I got a normal airflow, and -15 C on the CPU:
- now the air comes in from the side and the front, and gets through the back
- the cpu is at 45 c in normal usage
- the system temp is at 60 C in normal usage
- fan RPMs rarely exceed 960RPM
I believe this is much more inline with a normal behavior than before. :-)
Thanks for the tips, itsjasper!
Equinox1
Jun 11, 2015Guide
- gregb_proSep 01, 2015Aspirant
CPU temperature of 45 degrees C seems high; our Pro Business Edition CPU temperature runs below 25 degrees C (and system temperature is usually below 50 degrees C).
Consider checking the CPU heatsink bonding - ours needed thermal paste because the factory installed bonding was marginal (use good silver thermal paste).
