nickel22222's avatar
Jan 15, 2019
Fastest cpu options for RNDP6000-100NAS
I just upgraded bios to 2010 version for old RNDP6000.
I got a cheap E7600 2.6ghz running. Can I go faster, and if so what options?
  • That should be a 3.06GHz CPU, and it;s the fastest dual-core you can use.  None of the faster 1333MHz FSB chips in the Wolfdale family will work.
    Some have gone with a quad-core, which will give more throughput without being "faster".  But they have a higher TDP, so you need to be mindful of CPU cooling.  There is no room for a bigger cooler unless you cut a hole in the side of the case.
1 Reply
ProSupport for Business
