AllWin
May 23, 2012Aspirant
Feedback on ReadyNAS Duo v2
Hi, recently i bought Netgear ReadyNAS Duo V2 device, so i thought i will share my experiences so far. I'll be as short as possible. The good. - Excellent performance! I get 41-50 MB/s write and 7...
AllWin
May 25, 2012Aspirant
mdgm wrote: 5.3.5 final is now available.
Thank you once again, downloading right now. By the way, i'd like to perform "factory reset" after flashing latest firmware, is there any way to do it without losing all data? I can't find anything regarding that on FAQ section.
mdgm wrote: Recovering data using a PC would be a last resort and you should seek some instructions here if you ever need to do it.
It's just in case of device failure (knocking to the wood). Hopefully this won't happen any time soon.
mdgm wrote: Still not a replacement for doing backups of important data primarily stored on the NAS e.g. to a USB disk.
PapaBear wrote: Remember - the NAS is not a backup plan.
It's very unlikely that both HDD's will fail at same time, what else can happen?
